[Bio] / FigKernelScripts / run_model_generation_all.pl Repository:
Log of /FigKernelScripts/run_model_generation_all.pl
Tue Jul 31 18:45:21 2007 UTC (12 years, 6 months ago) by formsma
This script will generate models for all complete genomes in the seed. - Kevin
