[Bio] / FigKernelScripts / run_glimmer3.pl Repository:
Log of /FigKernelScripts/run_glimmer3.pl
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Tue Apr 14 18:19:17 2009 UTC (11 years, 1 month ago) by gdpusch
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.11: +10 -4 lines
Diff to previous 1.11 , to selected 1.7
Hopefully fixed the "long-orfs failure on short-contigs" bug.
Tue Apr 14 17:51:40 2009 UTC (11 years, 1 month ago) by gdpusch
Changes since 1.10: +27 -8 lines
Diff to previous 1.10 , to selected 1.7
Mon Nov 24 13:17:38 2008 UTC (11 years, 6 months ago) by gdpusch
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.9: +13 -3 lines
Diff to previous 1.9 , to selected 1.7
Skip too-short contigs during auto-training; added "-help" arg.
Wed Sep 10 22:19:38 2008 UTC (11 years, 8 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_release_2008_09_29
Diff to previous 1.8 , to selected 1.7
Fixed neglected linear topology swicth. -- /gdp
Tue Sep 9 22:56:16 2008 UTC (11 years, 8 months ago) by gdpusch
Added genetic-code switch to invocation of `glimmer3`. -- /gdp
Revision 1.7 - (view) (download) (as text) (annotate) - [selected]
Mon Sep 8 01:01:18 2008 UTC (11 years, 8 months ago) by gdpusch
Changes since 1.6: +12 -5 lines
Fixed botched contigs_file name during invocation of `glimmer3`. -- /gdp
Sun Sep 7 23:38:45 2008 UTC (11 years, 8 months ago) by overbeek
Changes since 1.5: +2 -5 lines
process arguments to allow the optional arguments to occur anywhere
Sun Sep 7 23:23:31 2008 UTC (11 years, 8 months ago) by overbeek
Changes since 1.4: +10 -9 lines
Thu Sep 4 17:46:10 2008 UTC (11 years, 8 months ago) by gdpusch
Changes since 1.3: +43 -9 lines
Fixes to get PATH and PWM matrix stuff straightened out. -- /gdp
Thu Jul 17 05:02:05 2008 UTC (11 years, 10 months ago) by gdpusch
Changes since 1.2: +35 -31 lines
Set paths to GLIMMER-3 and ELP from enviroment variables. -- /gdp
Wed Jul 16 21:59:37 2008 UTC (11 years, 10 months ago) by gdpusch
Changes since 1.1: +353 -178 lines
Near-complete re-write to correct initial misconception that GLIMMER v.3 was (almost) backward-compatible with v.2. -- /gdp
Tue May 30 21:06:24 2006 UTC (14 years ago) by overbeek
Diff to selected 1.7
Initial check-in. -- /gdp
