[Bio] / FigKernelScripts / run_gene_calling_scripts.pl Repository:
Log of /FigKernelScripts/run_gene_calling_scripts.pl
Links to mgrast_dev_05262011: (view) (download) (as text) (annotate)
Tue Apr 14 00:07:03 2009 UTC (10 years, 10 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
fix first arg on call to mark_picked_genes
Mon Apr 13 14:35:06 2009 UTC (10 years, 10 months ago) by overbeek
fix parms - add contigs
Sun Apr 12 15:18:42 2009 UTC (10 years, 10 months ago) by overbeek
script to run the gene calling programs
