[Bio] / FigKernelScripts / run_flux_optimization.pl Repository:
Log of /FigKernelScripts/run_flux_optimization.pl
Tue Oct 23 16:51:29 2007 UTC (12 years, 5 months ago) by mkubal
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
error checking
Mon Jul 23 20:35:38 2007 UTC (12 years, 8 months ago) by formsma
Fixed error statment that was incorrect - Kevin
Fri Jul 20 21:16:58 2007 UTC (12 years, 8 months ago) by formsma
This file invokes the glpsol linear solver to run a flux-balance optimization problem on
 a model generated for a give organism - Kevin
