[Bio] / FigKernelScripts / run_anno_to_pubseed_flow.sh Repository:
Log of /FigKernelScripts/run_anno_to_pubseed_flow.sh
Fri Feb 8 16:58:37 2013 UTC (6 years, 9 months ago) by olson
fix missing \
Tue Dec 11 21:43:46 2012 UTC (6 years, 11 months ago) by olson
Changes since 1.4: +3 -0 lines
Add 3702.1 to skiplist
Tue Jun 14 19:06:42 2011 UTC (8 years, 5 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928
Changes since 1.3: +8 -1 lines
Tweaks before installing into cron
Tue Jun 14 18:18:31 2011 UTC (8 years, 5 months ago) by olson
fix hashbang
Tue Jun 14 18:10:35 2011 UTC (8 years, 5 months ago) by olson
Changes since 1.1: +62 -8 lines
Annotation flow fixes.
Mon Jun 13 22:00:34 2011 UTC (8 years, 5 months ago) by olson
Updates to anno3->pubseed flow tools.
