[Bio] / FigKernelScripts / run_all_inference.pl Repository:
Log of /FigKernelScripts/run_all_inference.pl
Mon Aug 1 20:05:13 2011 UTC (8 years, 8 months ago) by olson
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.1: +9 -2 lines
Run on all genomes; update anything either missing a subsystems file or that haven't been updated in 2 days.
Tue Jun 21 21:37:44 2011 UTC (8 years, 9 months ago) by olson
CVS Tags: myrast_rel40
Scripts to run rapid_subsystem_inference_batch across all genomes, and to apply
the missing-in-subsystems output of that script to update subsystems.
