[Bio] / FigKernelScripts / representative_sequences.pl Repository:
Log of /FigKernelScripts/representative_sequences.pl
Wed Sep 29 19:21:54 2010 UTC (9 years, 4 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.5: +79 -143 lines
keep representative_sequences, but make it a shadow of the new svr_representative_sequences.pl
Wed Sep 29 15:33:38 2010 UTC (9 years, 4 months ago) by fangfang
Changes since 1.4: +35 -0 lines
Added -g option for genome IDs to keep.
Sat May 12 20:47:03 2007 UTC (12 years, 9 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_release_2008_09_29
Changes since 1.3: +5 -1 lines
Modifications to control ordering of sequences in representative sets and
in sequeneces added to an alignment.  Also new options to silently remove
sequences with duplicate ids.
Mon Mar 19 18:58:10 2007 UTC (12 years, 11 months ago) by golsen
Changes since 1.2: +27 -3 lines
Change in the representative sequences algorithm.  This could still use
more work.
Fri Feb 16 17:41:34 2007 UTC (13 years ago) by golsen
Changes since 1.1: +108 -29 lines
Major improvement in representative_sequences.pl.  Greatly improved
comments in representative_sequences.pm.
Wed Dec 20 23:08:17 2006 UTC (13 years, 2 months ago) by overbeek
add representative_sequences
