[Bio] / FigKernelScripts / renumber_seed_dir.pl Repository:
Log of /FigKernelScripts/renumber_seed_dir.pl
Wed Feb 22 22:13:45 2017 UTC (2 years, 8 months ago) by gdpusch
CVS Tags: HEAD
Somewhat dangerous fix to the sims files
Mon Jul 21 17:44:06 2014 UTC (5 years, 3 months ago) by olson
CVS Tags: rast_rel_2014_0729, rast_rel_2014_0912
bugfix.
Mon Jul 21 17:41:35 2014 UTC (5 years, 3 months ago) by olson
Changes since 1.5: +13 -3 lines
Add --old-id option to renumber_seed_dir to explicitly note the old form. The changes
made in 2012 here broke the RAST behavior needed during up.
Add the --old-id flag to Job48.pm.
Fri Jun 8 08:21:13 2012 UTC (7 years, 5 months ago) by gdpusch
Changes since 1.4: +19 -14 lines
Fixed bug that erroneous replaced _all_ FIDs with the new genome number, not just the old genome number
Wed Apr 28 22:12:25 2010 UTC (9 years, 6 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.3: +11 -7 lines
Don't fail if Features dir does not exist.
Wed Apr 28 21:58:51 2010 UTC (9 years, 6 months ago) by olson
Changes since 1.2: +15 -18 lines
New RAST genome upload support.
Mon Dec 5 18:56:38 2005 UTC (13 years, 11 months ago) by olson
CVS Tags: caBIG-05Apr06-00, caBIG-13Feb06-00, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_release_2008_09_29
Thu Jul 14 21:32:31 2005 UTC (14 years, 4 months ago) by olson
Script to change the genome id for a genome directory.
