[Bio] / FigKernelScripts / remove_rna_overlaps.pl Repository:
Log of /FigKernelScripts/remove_rna_overlaps.pl
Wed Jun 11 04:21:13 2008 UTC (11 years, 10 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_2008_0924, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912, rast_release_2008_09_29
Changes since 1.9: +1 -0 lines
Added setting of VERBOSE from metafile. -- /gdp
Fri Jun 6 18:00:31 2008 UTC (11 years, 10 months ago) by gdpusch
Changes since 1.8: +24 -6 lines
Replaced OOP invocation of FIG::display_id_and_seq() due to Bruce\'s unilateral and undiscussed synatax change; cleaned up a few typos in the debugging msgs. -- /gdp
Tue Sep 25 01:34:40 2007 UTC (12 years, 6 months ago) by gdpusch
CVS Tags: rast_rel_2008_04_23
Changes since 1.7: +7 -12 lines
Fixed handling of "split" locations. -- /gdp
Fri May 25 22:38:38 2007 UTC (12 years, 10 months ago) by gdpusch
Changes since 1.6: +57 -15 lines
Added support for alternate genetic codes. -- /gdp
Mon Dec 4 23:13:40 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.5: +12 -14 lines
Fixed serious sorting bug introduced by spurious "my". -- /gdp
Mon Dec 4 21:15:37 2006 UTC (13 years, 4 months ago) by olson
Changes since 1.4: +15 -12 lines
48-hr updates.
Thu Nov 30 23:04:16 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.3: +20 -1 lines
put in the fr2go stuff
Fri Nov 3 17:59:13 2006 UTC (13 years, 5 months ago) by overbeek
Changes since 1.2: +23 -13 lines
Removed several stupid bugs. -- /gdp
Mon Oct 23 17:08:58 2006 UTC (13 years, 5 months ago) by overbeek
Added code to overwrite tbl, recompute fasta
Mon Oct 23 15:00:03 2006 UTC (13 years, 5 months ago) by overbeek
Script to filter tbls against RNA overlaps. -- /gdp
