[Bio] / FigKernelScripts / relevant_pchsG.pl Repository:
Log of /FigKernelScripts/relevant_pchsG.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 2 months ago) by olson
Fri Sep 9 17:21:51 2005 UTC (14 years, 5 months ago) by olson
Fixes for coupling scripts.
Sun May 29 02:15:42 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.1: +23 -8 lines
Updated tools for functional coupling computation. Replace string
pges with (genome, peg) pairs.
Sat May 7 20:57:47 2005 UTC (14 years, 9 months ago) by overbeek
add routines for BigFC
