[Bio] / FigKernelScripts / register_features_with_clearinghouse.pl Repository:
Log of /FigKernelScripts/register_features_with_clearinghouse.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 6 months ago) by olson
Wed Aug 3 20:08:08 2005 UTC (14 years, 10 months ago) by olson
Diff to selected 1.2
New script to register feature IDs with the clearinghouse.
