[Bio] / FigKernelScripts / reduce_sims.pl Repository:
Log of /FigKernelScripts/reduce_sims.pl
Mon Jul 6 20:14:10 2009 UTC (10 years, 4 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.11: +56 -30 lines
fix nasty little bug that drops sims
Wed Sep 5 21:12:21 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.10: +55 -29 lines
rollup of changes for anno clearinghouse, RAST->SEED import.
Mon Jun 26 16:05:49 2006 UTC (13 years, 4 months ago) by olson
Error checking on write.
Mon Dec 5 18:56:38 2005 UTC (13 years, 11 months ago) by olson
Changes since 1.8: +17 -0 lines
Fri Mar 11 19:45:51 2005 UTC (14 years, 8 months ago) by olson
Changes since 1.7: +69 -0 lines
added some comments
Mon May 3 17:04:11 2004 UTC (15 years, 6 months ago) by overbeek
Changes since 1.6: +27 -9 lines
fixes to links in HTML.pm, code to sync systems after an update, and fixes to index.cgi and protein.cgi
Mon Mar 15 16:53:46 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.5: +7 -12 lines
fix to reduce_sims
Mon Mar 15 13:01:16 2004 UTC (15 years, 8 months ago) by overbeek
limit impact of huge organisms on reduce_sims
Mon Mar 15 12:54:47 2004 UTC (15 years, 8 months ago) by overbeek
Changes since 1.3: +12 -3 lines
Mon Mar 15 11:28:40 2004 UTC (15 years, 8 months ago) by overbeek
remove extra newlines from reduce_sims
Thu Jan 8 13:17:13 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.1: +14 -3 lines
fix lost sims
Mon Dec 1 20:46:40 2003 UTC (15 years, 11 months ago) by efrank
Makefile:
All the rest:
