[Bio] / FigKernelScripts / read_write_excel.pl Repository:
Log of /FigKernelScripts/read_write_excel.pl
Wed May 24 20:12:14 2006 UTC (13 years, 9 months ago) by overbeek
RAE: Initial release of a simple script to read and write excel files to allow easy parsing of data from annotators
