[Bio] / FigKernelScripts / rapid_propagation_plasmid.pl Repository:
Log of /FigKernelScripts/rapid_propagation_plasmid.pl
Thu Nov 11 17:32:17 2010 UTC (9 years ago) by disz
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.21: +2 -2 lines
Diff to previous 1.21
FigFam 6 digit problem
Wed Sep 2 13:40:17 2009 UTC (10 years, 2 months ago) by gdpusch
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.20: +47 -16 lines
Diff to previous 1.20
Added more bulletproofing, plus fallback to MGA if GLIMMER fails
Thu Aug 20 15:56:53 2009 UTC (10 years, 3 months ago) by arodri7
Changes since 1.19: +2 -2 lines
Diff to previous 1.19
changed subsystem running
Tue Aug 18 22:27:50 2009 UTC (10 years, 3 months ago) by gdpusch
Diff to previous 1.18
Fixed capitolization of "Circular" topology test.
Thu Jun 11 19:28:33 2009 UTC (10 years, 5 months ago) by arodri7
CVS Tags: rast_rel_2009_07_09
Changes since 1.17: +11 -11 lines
Diff to previous 1.17
corrected linear topology problem
Thu Jun 11 18:31:08 2009 UTC (10 years, 5 months ago) by gdpusch
Changes since 1.16: +56 -34 lines
Diff to previous 1.16
Fixed problems with "found" and "called_by" files; deferred subsystem analysis until after auto-assign.
Fri Jun 5 15:17:55 2009 UTC (10 years, 5 months ago) by gdpusch
Fixed typo in filename $tmpD/double_contig
Thu Apr 16 22:44:00 2009 UTC (10 years, 7 months ago) by arodri7
CVS Tags: rast_rel_2009_05_18
Changes since 1.14: +84 -33 lines
added glimmer and circular topoplogy check in pipeline
Mon Apr 6 20:41:46 2009 UTC (10 years, 7 months ago) by arodri7
Changes since 1.13: +101 -0 lines
added RNA computation to rapid_propagation_plasmid
Mon Mar 23 13:26:24 2009 UTC (10 years, 7 months ago) by arodri7
Changes since 1.12: +2 -2 lines
added fam to the found output
Tue Mar 17 20:40:46 2009 UTC (10 years, 8 months ago) by arodri7
Tue Mar 17 20:01:12 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.10: +1 -0 lines
Tue Mar 17 17:44:24 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.9: +4 -2 lines
Mon Mar 16 16:41:46 2009 UTC (10 years, 8 months ago) by arodri7
CVS Tags: rast_rel_2009_03_26
Changes since 1.8: +5 -5 lines
Mon Mar 16 14:41:22 2009 UTC (10 years, 8 months ago) by arodri7
re-added renumber
Mon Mar 16 14:39:31 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.6: +12 -5 lines
re-added renumber
Mon Mar 16 14:01:45 2009 UTC (10 years, 8 months ago) by arodri7
eliminate runumbering for now. Don't need it now in plasmids
Sun Mar 15 16:11:27 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.4: +3 -3 lines
added steps to rapid_propagation_plasmid
Sat Mar 14 15:27:04 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.3: +10 -5 lines
revised errors
Thu Mar 12 21:28:49 2009 UTC (10 years, 8 months ago) by olson
fix missing quotes
Tue Mar 10 18:39:09 2009 UTC (10 years, 8 months ago) by arodri7
Changes since 1.1: +12 -2 lines
updates to rapid_propagation_plasmid
Fri Mar 6 16:13:19 2009 UTC (10 years, 8 months ago) by arodri7
rapid_propagation_plasmid for fragments and plasmids. Runs metagene and scans the output sequences through FIGfams
