[Bio] / FigKernelScripts / rapid_propagation4.pl Repository:
Log of /FigKernelScripts/rapid_propagation4.pl
Links to mgrast_dev_03312011: (view) (download) (as text) (annotate)
Fri Jan 21 14:57:40 2011 UTC (9 years, 2 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, myrast_rel40
Changes since 1.6: +39 -14 lines
Fixed problem with virus/plasmid branch in "keep_genecalls" mode.
Tue Jan 18 11:30:00 2011 UTC (9 years, 2 months ago) by gdpusch
CVS Tags: rast_rel_2011_0119
Changes since 1.5: +11 -10 lines
Invoke correct_frameshifts with "-nofatal" option.
Sun Jan 16 19:48:50 2011 UTC (9 years, 2 months ago) by gdpusch
Fixed bug that wrote to "orgdir/proposed_functions" instead of "orgdir/assigned_functions."
Sun Jan 16 19:03:36 2011 UTC (9 years, 2 months ago) by gdpusch
Sun Jan 16 18:30:12 2011 UTC (9 years, 2 months ago) by gdpusch
Fixed bugs introduced by change to ANNOserver::find_genes_based_on_kmers() and botched small-genome branch invocation of subroutine "correct_frameshifts()."
Thu Dec 2 19:53:30 2010 UTC (9 years, 4 months ago) by gdpusch
CVS Tags: rast_rel_2010_1206
Corrected typo.
Sun Nov 28 15:45:03 2010 UTC (9 years, 4 months ago) by gdpusch
Initial checkin.
