[Bio] / FigKernelScripts / pull_sp_entries.pl Repository:
Log of /FigKernelScripts/pull_sp_entries.pl
Mon Dec 5 18:56:38 2005 UTC (14 years ago) by olson
Wed Sep 28 22:02:02 2005 UTC (14 years, 2 months ago) by overbeek
Extract entries matching a pattern from SwissProt/TrEMBL/UniProt .dat files. -- /gdp
