[Bio] / FigKernelScripts / pull_orfs.pl Repository:
Log of /FigKernelScripts/pull_orfs.pl
Mon Mar 13 12:34:28 2006 UTC (14 years ago) by overbeek
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_release_2008_09_29
Fixed case-sensitivity bug. -- /gdp
Mon Dec 5 18:56:38 2005 UTC (14 years, 3 months ago) by olson
Tue Apr 27 21:40:14 2004 UTC (15 years, 11 months ago) by overbeek
use FIG in pull_orfs
Tue Apr 27 21:31:30 2004 UTC (15 years, 11 months ago) by overbeek
add the old pull_orfs
