[Bio] / FigKernelScripts / promote_orfs_to_pegs.pl Repository:
Log of /FigKernelScripts/promote_orfs_to_pegs.pl
Links to mgrast_release_3_0_1: (view) (download) (as text) (annotate)
Tue Nov 23 18:22:21 2010 UTC (9 years ago) by gdpusch
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.14: +57 -43 lines
Code restructured, and modified to fail gracefully if there are no closest genomes.
Fri Jul 16 15:09:17 2010 UTC (9 years, 4 months ago) by gdpusch
Changes since 1.13: +10 -2 lines
Added support for both "closest.genomes" and "neighbors" files.
Wed Feb 13 14:54:27 2008 UTC (11 years, 9 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_release_2008_09_29
Changes since 1.12: +29 -9 lines
Final clean-up. -- /gdp
Thu Dec 6 00:07:06 2007 UTC (12 years ago) by gdpusch
Changes since 1.11: +64 -54 lines
Added bulletproofing against empty "neighbors" file. -- /gdp
Wed Oct 10 20:24:21 2007 UTC (12 years, 1 month ago) by gdpusch
Changes since 1.10: +4 -6 lines
Minor revision to comments. -- /gdp
Thu Sep 13 19:55:02 2007 UTC (12 years, 2 months ago) by olson
Changes since 1.9: +4 -0 lines
add comment
Fri Jun 8 18:11:21 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.8: +5 -6 lines
add use strict, fix crash resulting from badly scoped var.
Thu Jun 7 19:01:48 2007 UTC (12 years, 6 months ago) by olson
Changes since 1.7: +24 -18 lines
disable auto_assign at this stage
Thu May 17 12:44:39 2007 UTC (12 years, 6 months ago) by gdpusch
Changes since 1.6: +4 -6 lines
Attempt to prevent failure during clean-up from NFS leavings. -- /gdp
Tue Nov 14 17:35:44 2006 UTC (13 years ago) by olson
Changes since 1.5: +10 -1 lines
Changes for rapid propagation on the cluster.
Sat Oct 28 14:27:05 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.4: +91 -2 lines
Added code to BLAST ORFs before promoting them, and to run `auto_assign` on the result. -- /gdp
Thu Oct 5 00:28:58 2006 UTC (13 years, 2 months ago) by overbeek
fixes to rapid prop technology and added diffsF.cgi
Fri Sep 15 11:25:42 2006 UTC (13 years, 2 months ago) by overbeek
fix yet another bug in all_bbhs - this one relating to deleted_fids
Wed Sep 13 03:27:45 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.1: +8 -1 lines
Added some clean-up logic. -- /gdp
Mon Sep 4 22:24:32 2006 UTC (13 years, 3 months ago) by overbeek
add promote_orfs_to_pegs
