[Bio] / FigKernelScripts / process_new_sims.pl Repository:
Log of /FigKernelScripts/process_new_sims.pl
Links to caBIG-05Apr06-00: (view) (download) (as text) (annotate)
Mon Dec 5 18:56:38 2005 UTC (14 years, 7 months ago) by olson
Wed Nov 16 05:25:18 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.2: +36 -6 lines
allow reading of sims dirs from stdin if the pathname is -
Fri Mar 11 16:36:51 2005 UTC (15 years, 4 months ago) by overbeek
Changes since 1.1: +20 -19 lines
Significant changes to syntax and structure. -- /gdp
Mon Dec 1 20:46:40 2003 UTC (16 years, 7 months ago) by efrank
Diff to selected 1.2
Makefile:
All the rest:
