[Bio] / FigKernelScripts / predict_starts.pl Repository:
Log of /FigKernelScripts/predict_starts.pl
Links to merge-trunktag-bobdev_news-1: (view) (download) (as text) (annotate)
Mon Apr 4 21:46:44 2005 UTC (14 years, 8 months ago) by overbeek
CVS Tags: Root-bobdev_news, efrank-preMakefileToStandardMk, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
swap clear.corrections and proposed.corrections in calling starts
Mon Apr 4 21:13:08 2005 UTC (14 years, 8 months ago) by overbeek
Changes since 1.1: +7 -1 lines
fixes to start predictions
Mon Jan 17 01:27:44 2005 UTC (14 years, 10 months ago) by overbeek
add start prediction code
