[Bio] / FigKernelScripts / predict_starts.pl Repository:
Log of /FigKernelScripts/predict_starts.pl
Fri Nov 30 21:53:05 2007 UTC (12 years, 2 months ago) by gdpusch
Changes since 1.7: +11 -3 lines
Diff to previous 1.7 , to selected 1.5
Added FIGV support. -- /gdp
Mon Dec 5 18:56:38 2005 UTC (14 years, 1 month ago) by olson
Sun Jul 31 01:09:59 2005 UTC (14 years, 6 months ago) by overbeek
 fixes to pick_gene_boundaries
Thu Jul 28 17:45:37 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.4: +6 -6 lines
modifications to correcting starts code
Sun Jul 24 15:54:40 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.3: +4 -2 lines
fixes to start predictions
Mon Apr 4 21:46:44 2005 UTC (14 years, 9 months ago) by overbeek
CVS Tags: Root-bobdev_news, efrank-preMakefileToStandardMk, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
swap clear.corrections and proposed.corrections in calling starts
Mon Apr 4 21:13:08 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.1: +7 -1 lines
Mon Jan 17 01:27:44 2005 UTC (15 years ago) by overbeek
Diff to selected 1.5
add start prediction code
