[Bio] / FigKernelScripts / predict_scenarios.pl Repository:
Log of /FigKernelScripts/predict_scenarios.pl
Tue Jul 17 19:40:06 2007 UTC (12 years, 8 months ago) by formsma
Changes since 1.1: +8 -0 lines
Added code to automatically run 'run_scenarios All' if it hasn't been run. These data is required for this script to run - Kevin
Tue Jul 17 16:21:50 2007 UTC (12 years, 8 months ago) by formsma
This script prints a two column table of peg-to-scenario mappings for a given genome - Kevin
