[Bio] / FigKernelScripts / potentially_cotranscribed.pl Repository:
Log of /FigKernelScripts/potentially_cotranscribed.pl
Sat Aug 14 14:39:36 2004 UTC (15 years, 6 months ago) by overbeek
fixes to aliases_of and added potentially_cotranscribed
