[Bio] / FigKernelScripts / pg_make_initial_models.pl Repository:
Log of /FigKernelScripts/pg_make_initial_models.pl
Tue Jul 16 17:06:24 2013 UTC (6 years, 4 months ago) by overbeek
Changes since 1.11: +5 -0 lines
watch out for failing models
Wed May 29 18:25:16 2013 UTC (6 years, 5 months ago) by disz
Changes since 1.10: +7 -5 lines
Workspace work around
Wed May 29 18:09:50 2013 UTC (6 years, 5 months ago) by disz
require workspace
Wed May 29 18:03:08 2013 UTC (6 years, 5 months ago) by disz
Changes since 1.8: +23 -6 lines
Require Workspace
Fri May 10 16:10:03 2013 UTC (6 years, 6 months ago) by overbeek
Changes since 1.7: +23 -0 lines
changes in invoking model seed
Fri Mar 8 16:14:20 2013 UTC (6 years, 8 months ago) by overbeek
Changes since 1.6: +2 -1 lines
set PATH
Fri Mar 8 08:44:14 2013 UTC (6 years, 8 months ago) by overbeek
set PATH variable for KB stuff
Fri Mar 8 08:35:24 2013 UTC (6 years, 8 months ago) by overbeek
make initial models - no gapfilling
Mon Mar 4 01:40:02 2013 UTC (6 years, 8 months ago) by overbeek
Changes since 1.3: +3 -0 lines
place events on the tree
Fri Mar 1 20:05:42 2013 UTC (6 years, 8 months ago) by overbeek
Changes since 1.2: +3 -0 lines
URLs
Fri Mar 1 18:48:15 2013 UTC (6 years, 8 months ago) by overbeek
fix comment
Fri Mar 1 18:43:04 2013 UTC (6 years, 8 months ago) by overbeek
get initial models
