[Bio] / FigKernelScripts / pegs.pl Repository:
Log of /FigKernelScripts/pegs.pl
Thu May 20 18:04:09 2004 UTC (15 years, 9 months ago) by overbeek
interval stuff
Mon May 10 02:35:34 2004 UTC (15 years, 9 months ago) by overbeek
add pegs and fid2dna
