[Bio] / FigKernelScripts / partition_prots.pl Repository:
Log of /FigKernelScripts/partition_prots.pl
Mon Mar 9 14:50:34 2009 UTC (11 years ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.3: +17 -2 lines
check to make sure sims are working
Tue Dec 16 01:05:41 2008 UTC (11 years, 3 months ago) by overbeek
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.2: +15 -14 lines
fixes on partitioning
Fri Sep 12 01:47:15 2008 UTC (11 years, 6 months ago) by overbeek
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_release_2008_09_29
Changes since 1.1: +10 -11 lines
fixes to FIGV.pm, CompareMR.pm and FIG.pm to support comparison of metabolic reconstructions
Fri Jul 4 15:28:08 2008 UTC (11 years, 9 months ago) by overbeek
add code to partition proteins to support rapid similarity computations
