[Bio] / FigKernelScripts / parse_genbank.pl Repository:
Log of /FigKernelScripts/parse_genbank.pl
Wed May 14 15:56:47 2008 UTC (11 years, 10 months ago) by wilke
Changes since 1.16: +21 -2 lines
Diff to previous 1.16
ids have prefixes now , e.g for locus tags locus|ID
Tue Sep 11 04:27:40 2007 UTC (12 years, 6 months ago) by gdpusch
CVS Tags: rast_rel_2008_04_23
Changes since 1.15: +130 -174 lines
Fixed ORIGIN parsing bug, blank line parsing bug. -- /gdp
Thu Nov 30 21:02:57 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.14: +3 -0 lines
fix parse_genbank to extract genome and taxonomy a bit more accurately
Thu Nov 30 20:52:40 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.13: +20 -3 lines
Mon May 29 00:04:13 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.12: +13 -16 lines
Fixed bug parsing function. -- /gdp
Changes since 1.11: +17 -0 lines
Sun Oct 2 14:54:34 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.10: +22 -8 lines
Fixed bug in function-parsing logic. -- /gdp
Wed Jun 22 01:18:03 2005 UTC (14 years, 9 months ago) by gdpusch
Changes since 1.9: +8 -6 lines
Modified to not trim STOP off locus. -- /gdp
Fri Jul 16 21:54:14 2004 UTC (15 years, 8 months ago) by gdpusch
CVS Tags: Root-bobdev_news, efrank-preMakefileToStandardMk
Changes since 1.8: +80 -25 lines
Corrected bugs; added checks and debugging information for loci whose sequences could not be extracted.
Sat Jun 12 11:15:56 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.7: +12 -5 lines
update parse_genbank
Sat Jun 5 19:55:34 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.6: +4 -1 lines
do not keep pseudo genes in parse_genbank
Sat Jun 5 13:30:22 2004 UTC (15 years, 9 months ago) by overbeek
fix serious bug causing truncation of CDSs in parse_genbank
Wed Mar 3 21:03:42 2004 UTC (16 years ago) by gdpusch
Fixed parsing error. -- /gdp
Thu Feb 5 03:29:26 2004 UTC (16 years, 1 month ago) by overbeek
Changes since 1.3: +88 -20 lines
allow complete option on genomes
Fri Jan 9 19:18:21 2004 UTC (16 years, 2 months ago) by efrank
Changes since 1.2: +12 -10 lines
fix parse_genbank bugs
Wed Dec 3 19:39:29 2003 UTC (16 years, 3 months ago) by efrank
CVS Tags: delong-01, delong-02
Changes since 1.1: +86 -10 lines
fixed a bunch of changes
Mon Dec 1 20:46:40 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: V00-00-00, V00-00-01
Makefile:
All the rest:
