[Bio] / FigKernelScripts / parse_genbank.pl Repository:
Log of /FigKernelScripts/parse_genbank.pl
Fri Feb 27 07:17:03 2015 UTC (5 years, 1 month ago) by gdpusch
CVS Tags: HEAD
Changes since 1.33: +10 -5 lines
Diff to previous 1.33
Fixed parsing failure in case when TAXONOMY string consists of a single field without semicolons.
Tue Jan 11 20:28:25 2011 UTC (9 years, 2 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.32: +42 -33 lines
Diff to previous 1.32
Added "-user_trans_only" flag.
Tue Aug 31 14:33:30 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.31: +1 -1 lines
Diff to previous 1.31
Allow files with spaces in the name.
Tue Aug 10 20:05:39 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.30: +20 -2 lines
Diff to previous 1.30
Allow -i=input-file for specifying input, instead of stdin.
Tue Aug 10 19:35:36 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.29: +15 -11 lines
Diff to previous 1.29
Change to use SeedUtils instead of FIG.
Sun Jun 27 19:40:57 2010 UTC (9 years, 9 months ago) by olson
Changes since 1.28: +4 -4 lines
Diff to previous 1.28
fixes for paths with spaces
Fri Feb 12 17:32:59 2010 UTC (10 years, 1 month ago) by gdpusch
CVS Tags: rast_rel_2010_0526
Changes since 1.27: +7 -4 lines
Diff to previous 1.27
Fixed fact that we are still handling RNA functions as aliases, not functions.
Tue Jan 19 21:23:40 2010 UTC (10 years, 2 months ago) by gdpusch
CVS Tags: rast_rel_2010_0118
Changes since 1.26: +46 -30 lines
Diff to previous 1.26
Fixed mistrapping of "fuzzy" boundaries.
Mon Jan 11 22:42:51 2010 UTC (10 years, 2 months ago) by gdpusch
Changes since 1.25: +45 -46 lines
Diff to previous 1.25
Fixed bug in code for missing translations.
Wed Jan 6 21:45:53 2010 UTC (10 years, 2 months ago) by gdpusch
Changes since 1.24: +1 -0 lines
Diff to previous 1.24
Fixed "newline in /db_xref" bug.
Fri Nov 6 19:36:49 2009 UTC (10 years, 4 months ago) by redwards
Diff to previous 1.23
correcting ORIGIN regexp
Thu Mar 26 20:34:07 2009 UTC (11 years ago) by gdpusch
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.22: +13 -12 lines
Diff to previous 1.22
Fixed parsing bug on optional arguments
Wed Mar 4 05:49:34 2009 UTC (11 years, 1 month ago) by gdpusch
CVS Tags: rast_rel_2009_03_26
Changes since 1.21: +6 -1 lines
Diff to previous 1.21
Fixed spurious newlines in assigned functions and missing aliases; removed fatal abort if Genbank file does not contain any CDS entries.
Wed Mar 4 05:40:23 2009 UTC (11 years, 1 month ago) by gdpusch
Diff to previous 1.20
Wed Mar 4 05:34:49 2009 UTC (11 years, 1 month ago) by gdpusch
Changes since 1.19: +21 -16 lines
Diff to previous 1.19
Fri Feb 6 18:52:59 2009 UTC (11 years, 1 month ago) by olson
Diff to previous 1.18
bugfix
Fri Jan 30 13:03:27 2009 UTC (11 years, 2 months ago) by gdpusch
CVS Tags: rast_rel_2009_02_05
Changes since 1.17: +314 -155 lines
Diff to previous 1.17
Cleaned up code; added "use strict" and "use warnings"; added annotations and EC_number extraction.
Wed May 14 15:56:47 2008 UTC (11 years, 10 months ago) by wilke
Changes since 1.16: +21 -2 lines
Diff to previous 1.16
ids have prefixes now , e.g for locus tags locus|ID
Tue Sep 11 04:27:40 2007 UTC (12 years, 6 months ago) by gdpusch
CVS Tags: rast_rel_2008_04_23
Changes since 1.15: +130 -174 lines
Fixed ORIGIN parsing bug, blank line parsing bug. -- /gdp
Thu Nov 30 21:02:57 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.14: +3 -0 lines
fix parse_genbank to extract genome and taxonomy a bit more accurately
Thu Nov 30 20:52:40 2006 UTC (13 years, 4 months ago) by overbeek
Changes since 1.13: +20 -3 lines
Mon May 29 00:04:13 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.12: +13 -16 lines
Fixed bug parsing function. -- /gdp
Changes since 1.11: +17 -0 lines
Sun Oct 2 14:54:34 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.10: +22 -8 lines
Fixed bug in function-parsing logic. -- /gdp
Wed Jun 22 01:18:03 2005 UTC (14 years, 9 months ago) by gdpusch
Changes since 1.9: +8 -6 lines
Modified to not trim STOP off locus. -- /gdp
Fri Jul 16 21:54:14 2004 UTC (15 years, 8 months ago) by gdpusch
CVS Tags: Root-bobdev_news, efrank-preMakefileToStandardMk
Changes since 1.8: +80 -25 lines
Corrected bugs; added checks and debugging information for loci whose sequences could not be extracted.
Sat Jun 12 11:15:56 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.7: +12 -5 lines
update parse_genbank
Sat Jun 5 19:55:34 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.6: +4 -1 lines
do not keep pseudo genes in parse_genbank
Sat Jun 5 13:30:22 2004 UTC (15 years, 10 months ago) by overbeek
fix serious bug causing truncation of CDSs in parse_genbank
Wed Mar 3 21:03:42 2004 UTC (16 years, 1 month ago) by gdpusch
Fixed parsing error. -- /gdp
Thu Feb 5 03:29:26 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.3: +88 -20 lines
allow complete option on genomes
Fri Jan 9 19:18:21 2004 UTC (16 years, 2 months ago) by efrank
Changes since 1.2: +12 -10 lines
fix parse_genbank bugs
Wed Dec 3 19:39:29 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: delong-01, delong-02
Changes since 1.1: +86 -10 lines
fixed a bunch of changes
Mon Dec 1 20:46:40 2003 UTC (16 years, 4 months ago) by efrank
CVS Tags: V00-00-00, V00-00-01
Makefile:
All the rest:
