[Bio] / FigKernelScripts / package_annotations.pl Repository:
Log of /FigKernelScripts/package_annotations.pl
Changes since 1.8: +17 -0 lines
Tue Sep 6 18:52:35 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.7: +7 -0 lines
Make annotations_made_fast return new Annotation objects instead of arrays of data.
Add the Annotation object.
Thu Sep 1 18:23:49 2005 UTC (14 years, 5 months ago) by olson
Changes since 1.6: +31 -8 lines
Add fast= flag to package_annotations, and the %options array in P2Pupdate::pacakge_annotations
to support it. (skip_aliases and skip_sequences support). Makes export of annotations to a
SEED that you know has the same data for the same ID *MUCH* faster.
Thu Apr 29 20:28:30 2004 UTC (15 years, 9 months ago) by overbeek
CVS Tags: Root-bobdev_news, efrank-preMakefileToStandardMk, merge-bobdev_news-1, merge-bobdev_news-2, merge-bodev_news-3, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
fixes relating to syncing systems during update
Thu Apr 1 17:21:18 2004 UTC (15 years, 10 months ago) by overbeek
Changes since 1.4: +28 -8 lines
make parammeters consistent for assignments and annotations
Wed Mar 31 16:32:22 2004 UTC (15 years, 10 months ago) by overbeek
attempt to fix package/install for p2p
Tue Dec 23 22:17:56 2003 UTC (16 years, 1 month ago) by efrank
handle null length annotation exchanges
Tue Dec 23 21:57:17 2003 UTC (16 years, 1 month ago) by efrank
Fixed typo genoomes
Mon Dec 1 20:46:40 2003 UTC (16 years, 2 months ago) by efrank
Makefile:
All the rest:
