[Bio] / FigKernelScripts / p3-project-subsystems.pl Repository:
View of /FigKernelScripts/p3-project-subsystems.pl
Revision 1.2 - (download) (as text) (annotate)
Fri Mar 16 01:24:56 2018 UTC (20 months ago) by parrello
CVS Tags: HEAD
Changes copied from SEEDtk project.
#!/usr/bin/env perl
# Copyright (c) 2003-2015 University of Chicago and Fellowship
# Public License.
use strict;
use warnings;
use P3DataAPI;
use SubsystemProjector;
use File::Copy::Recursive;
use ScriptUtils;
=head1 Project Subsystems onto PATRIC Genomes
    p3-project-subystems.pl [ options ] outDir genome1 genome2 ... genomeN
This script will examine PATRIC genomes and project subsystems onto them. The resulting GTOs will be output to the
specified output directory.
=head2 Parameters
The positional parameters are the name of the output directory followed by one or more PATRIC genome IDs.
The command-line options are the following:
=over 4
=item roleFile
Name of a tab-delimited file containing [role checksum, subsystem name] pairs.
=item variantFile
Name of a tab-delimited file containing in each record (0) a subsystem name, (1) a variant code, and
(2) a space-delimited list of role checksums.
=back
=cut
$| = 1;
# Get the command-line parameters.
my $opt = ScriptUtils::Opts('outDir genome1 genome2 ... genomeN',
        ['roleFile|r=s', 'name of file containing subsystems for roles', { required => 1 }],
        ['variantFile|v=s', 'name of file containing variant maps', { required => 1}]
# Get the positional parameters.
my ($outDir, @genomes) = @ARGV;
# Verify the parameters.
if (! $outDir) {
    die "No output directory specified.";
} elsif (! -d $outDir) {
    print "Creating $outDir.\n";
    File::Copy::Recursive::pathmk($outDir) || die "Could not create output directory $outDir: $!";
if (! @genomes) {
    die "No genomes specified.";
# Connect to PATRIC.
print "Connecting to PATRIC.\n";
my $p3 = P3DataAPI->new();
# Create the subsystem projector.
print "Initializing projector.\n";
my $projector = SubsystemProjector->new($opt->rolefile, $opt->variantfile);
# Get the statistics object.
my $stats = $projector->stats;
# Loop through the genomes.
for my $genome (@genomes) {
    print "Reading $genome.\n";
    my $gto = $p3->gto_of($genome);
    if (! $gto) {
        print "ERROR: genome not found.\n";
        $stats->Add(badGenome => 1);
    } else {
        print "Computing subsystems.\n";
        my $subsystemHash = $projector->ProjectForGto($gto, store => 1);
        my $count = scalar(keys %$subsystemHash);
        print "$count subsystems found.\n";
        my $outFile = "$outDir/$genome.gto";
        print "Writing output to $outFile.\n";
        $gto->destroy_to_file($outFile);
print "All done: " . $stats->Show();
