[Bio] / FigKernelScripts / p3-get-feature-sequence.pl Repository:
Log of /FigKernelScripts/p3-get-feature-sequence.pl
Fri Mar 16 01:24:56 2018 UTC (20 months ago) by parrello
CVS Tags: HEAD
Changes since 1.5: +51 -86 lines
Changes copied from SEEDtk project.
Thu Oct 5 17:20:49 2017 UTC (2 years, 1 month ago) by olson
Add metadata to the query_cb callback. Also use the return value of query_cb
to determine whether the query continues (return true value to continue the query, return
false value to terminate the query).
Wed Jun 21 18:07:50 2017 UTC (2 years, 5 months ago) by parrello
Changes since 1.3: +7 -0 lines
Wed Dec 21 19:15:13 2016 UTC (2 years, 10 months ago) by olson
fix for empty fid field.
Mon Nov 7 21:47:58 2016 UTC (3 years ago) by olson
Changes since 1.1: +17 -4 lines
support id on command line
Thu Oct 27 18:16:23 2016 UTC (3 years ago) by olson
Script to pull feature data from P3 data api.
