[Bio] / FigKernelScripts / p3-extract-gto.pl Repository:
Log of /FigKernelScripts/p3-extract-gto.pl
Fri Mar 16 01:24:56 2018 UTC (20 months ago) by parrello
CVS Tags: HEAD
Changes since 1.5: +68 -64 lines
Changes copied from SEEDtk project.
Wed Jun 21 18:07:50 2017 UTC (2 years, 5 months ago) by parrello
Changes since 1.4: +7 -0 lines
Thu Nov 3 18:39:40 2016 UTC (3 years ago) by olson
Changes since 1.3: +3 -0 lines
Fix feature type selection.
Thu Nov 3 16:57:56 2016 UTC (3 years ago) by olson
Changes since 1.2: +24 -2 lines
Add aliases to generated output.
Thu Nov 3 16:40:35 2016 UTC (3 years ago) by olson
Changes since 1.1: +14 -1 lines
Add domain and taxonomy.
Thu Nov 3 16:23:40 2016 UTC (3 years ago) by olson
GTO from patric.
