[Bio] / FigKernelScripts / nmpdr2gff.pl Repository:
Log of /FigKernelScripts/nmpdr2gff.pl
Thu Feb 2 05:15:03 2006 UTC (14 years ago) by overbeek
RAE: Changes to gff3 files for NMPDR and adding nmpdr2gff for creating the files
