[Bio] / FigKernelScripts / merge_translation_rules.pl Repository:
Log of /FigKernelScripts/merge_translation_rules.pl
Diff to previous 1.6 , to selected 1.1
Tue Feb 3 23:08:53 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.5: +6 -2 lines
fix translation rules
Tue Feb 3 20:09:02 2004 UTC (16 years, 2 months ago) by overbeek
Changes since 1.4: +6 -1 lines
fix translatiion merge
Tue Dec 23 17:56:33 2003 UTC (16 years, 3 months ago) by efrank
handle missing function.synonyms gracefully
Tue Dec 23 17:41:47 2003 UTC (16 years, 3 months ago) by efrank
p2p stuff
Tue Dec 23 17:38:35 2003 UTC (16 years, 3 months ago) by efrank
Changes since 1.1: +13 -8 lines
fixes to p2p
Mon Dec 1 20:46:40 2003 UTC (16 years, 4 months ago) by efrank
Makefile:
All the rest:
