[Bio] / FigKernelScripts / md5.c Repository:
Log of /FigKernelScripts/md5.c
Links to mgrast_dev_06072011: (view) (download) (as text) (annotate)
Mon Dec 5 18:59:41 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.2: +18 -17 lines
Doh, put proper comments in for C code.
Mon Dec 5 18:56:37 2005 UTC (14 years, 6 months ago) by olson
Changes since 1.1: +18 -1 lines
Tue Mar 8 21:06:04 2005 UTC (15 years, 2 months ago) by olson
Diff to selected 1.3
Add support for computing MD5 checksums for contigs and genomes.
The checksum of a genome is defined as the checksum of its signature file. The signature
file consists of tab-separated lines, one for each contig, ordered by the contig id.
Each line contains the contig ID, the length of the contig in nucleotides, and the
MD5 checksum of the nucleotide data, with uppercase letters forced to lower case.
The signature file is written by index_contigs to
The genome's md5 checksum is written by index_contigs to <genomedir>/MD5SUM.
The md5.c code here is extracted from the Perl Digest::MD5 module. We use the perl
configuration to build it so that it will work correctly on 64-bit architectures.
