[Bio] / FigKernelScripts / make_subsystems_from_clusters.pl Repository:
Log of /FigKernelScripts/make_subsystems_from_clusters.pl
Sat Jun 4 00:15:09 2005 UTC (14 years, 10 months ago) by overbeek
fixes to generation of subsystems from clusters
Fri Jun 3 23:09:10 2005 UTC (14 years, 10 months ago) by overbeek
fix bug in compare_regions
Fri Jun 3 15:22:30 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.1: +11 -9 lines
save status of clusters to subsystems - still being debugged
Fri May 6 19:04:14 2005 UTC (14 years, 10 months ago) by overbeek
add buggy make_subsystems_from_clusters
