[Bio] / FigKernelScripts / make_sp_desc_with_org.pl Repository:
Log of /FigKernelScripts/make_sp_desc_with_org.pl
Wed Sep 28 21:55:10 2005 UTC (14 years, 5 months ago) by overbeek
Extract description and organism data lines from SwissProt/TrEMBL/UniProt .dat files. -- /gdp
