[Bio] / FigKernelScripts / make_protein_sets.pl Repository:
Log of /FigKernelScripts/make_protein_sets.pl
Mon May 3 21:59:26 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.2: +9 -4 lines
Fixed out-of-mempoy error by replacing backticked grep through NR with pipe-open grep through NR. -- /gdp
Fri Apr 23 21:49:03 2004 UTC (15 years, 10 months ago) by overbeek
fixes to index.cgi to blast against all complete
Mon Dec 1 20:46:40 2003 UTC (16 years, 2 months ago) by efrank
Makefile:
All the rest:
