[Bio] / FigKernelScripts / make_phob_from_seqs.pl Repository:
Log of /FigKernelScripts/make_phob_from_seqs.pl
Tue May 10 12:03:39 2005 UTC (14 years, 11 months ago) by overbeek
fixes to using trees under subsystems
Mon May 9 02:14:13 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.4: +7 -2 lines
Translate selenocystein chars to "X". -- /gdp
Mon May 2 22:58:12 2005 UTC (14 years, 11 months ago) by overbeek
delete outfile in make_phob_from_seqs
Thu Apr 14 11:45:18 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.2: +4 -4 lines
use neighbor joining, not fitch, to build trees
Tue Apr 12 21:25:21 2005 UTC (15 years ago) by overbeek
Changes since 1.1: +9 -3 lines
fixes to trim_sequences and make_phob_from_seqs
Tue Apr 5 18:30:12 2005 UTC (15 years ago) by overbeek
pu => phob
