[Bio] / FigKernelScripts / make_parallel_proml_run.pl Repository:
Log of /FigKernelScripts/make_parallel_proml_run.pl
Sat Jan 13 03:22:44 2007 UTC (13 years, 1 month ago) by overbeek
Changes since 1.1: +54 -27 lines
add rates to phylogeny stuff
Sat Jan 6 17:39:41 2007 UTC (13 years, 1 month ago) by overbeek
make sure tree insertion code is all committed
