[Bio] / FigKernelScripts / make_match_table.pl Repository:
Log of /FigKernelScripts/make_match_table.pl
Links to mgrast_rel_2008_0924: (view) (download) (as text) (annotate)
Thu Jul 1 21:47:32 2004 UTC (15 years, 10 months ago) by overbeek
up max size of bbh extras
