[Bio] / FigKernelScripts / make_match_table.pl Repository:
Log of /FigKernelScripts/make_match_table.pl
Links to rast_rel_2008_09_29: (view) (download) (as text) (annotate)
Thu Jul 1 21:47:32 2004 UTC (16 years ago) by overbeek
Diff to selected 1.2
up max size of bbh extras
