[Bio] / FigKernelScripts / make_maps_from_sub.py Repository:
Log of /FigKernelScripts/make_maps_from_sub.py
Thu Jul 1 22:19:02 2004 UTC (15 years, 5 months ago) by olson
Changes since 1.3: +2 -1 lines
test for existence of link before referring to it.
Wed Jun 23 15:41:33 2004 UTC (15 years, 5 months ago) by disz
Changes since 1.2: +7 -0 lines
local map fixes, removed extra subsystem logon lines
Wed Jun 16 16:08:20 2004 UTC (15 years, 6 months ago) by olson
Changes since 1.1: +41 -5 lines
Clean up map support.
Wed Jun 16 14:57:28 2004 UTC (15 years, 6 months ago) by olson
New file.
