[Bio] / FigKernelScripts / make_fam_tabs.pl Repository:
Log of /FigKernelScripts/make_fam_tabs.pl
Links to caBIG-13Feb06-00: (view) (download) (as text) (annotate)
Wed Dec 21 19:14:13 2005 UTC (14 years, 5 months ago) by overbeek
RAE: Protein Families interface and construction
Mon Nov 28 04:31:07 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.2: +32 -17 lines
updating protein families
Mon Aug 1 18:52:58 2005 UTC (14 years, 10 months ago) by overbeek
Changes since 1.1: +8 -1 lines
update stuff relating to protein families
Tue Jul 12 00:34:32 2005 UTC (14 years, 10 months ago) by overbeek
updates to build protein families
