[Bio] / FigKernelScripts / make_external_sequence_data.pl Repository:
Log of /FigKernelScripts/make_external_sequence_data.pl
Wed Nov 22 21:01:19 2006 UTC (13 years ago) by olson
remove .pl from invocations
Fri Oct 6 16:27:28 2006 UTC (13 years, 2 months ago) by overbeek
Diff to selected 1.2
Script to build (most of) the external sequence directories. -- /gdp
