[Bio] / FigKernelScripts / make_coreg_conjectures_based_on_subsys.pl Repository:
Log of /FigKernelScripts/make_coreg_conjectures_based_on_subsys.pl
Mon May 17 13:05:46 2010 UTC (9 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
loosen parms
Tue Apr 20 18:32:51 2010 UTC (9 years, 7 months ago) by overbeek
CVS Tags: rast_rel_2010_0526
Changes since 1.1: +75 -5 lines
minor fixes
Tue Apr 20 15:43:06 2010 UTC (9 years, 7 months ago) by overbeek
generation of conjectured coregulated sets
