[Bio] / FigKernelScripts / make_coreg_conjectures_based_on_subsys.pl Repository:
Log of /FigKernelScripts/make_coreg_conjectures_based_on_subsys.pl
Tue Apr 19 19:24:07 2011 UTC (8 years, 6 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
allow working from estiomates of SS
Tue Apr 19 00:11:18 2011 UTC (8 years, 6 months ago) by overbeek
Changes since 1.4: +27 -12 lines
take subsystem estimates optionally
Fri Jan 7 22:20:38 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33, rast_rel_2011_0119
Changes since 1.3: +18 -10 lines
Update to expression pipeline code
Mon May 17 13:05:46 2010 UTC (9 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
loosen parms
Tue Apr 20 18:32:51 2010 UTC (9 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2010_0526
Changes since 1.1: +75 -5 lines
minor fixes
Tue Apr 20 15:43:06 2010 UTC (9 years, 6 months ago) by overbeek
generation of conjectured coregulated sets
