[Bio] / FigKernelScripts / make_close.pl Repository:
Log of /FigKernelScripts/make_close.pl
Fri Jul 14 22:21:16 2006 UTC (13 years, 8 months ago) by parrello
Fixed obsolete form of boundaries_of.
Sun Feb 19 04:15:44 2006 UTC (14 years, 1 month ago) by overbeek
minor fixes to auto_assign
Thu Feb 16 22:03:22 2006 UTC (14 years, 1 month ago) by overbeek
Changes since 1.4: +22 -3 lines
fix Data mining tutorial
Tue Jun 21 15:21:26 2005 UTC (14 years, 9 months ago) by olson
CVS Tags: caBIG-00-00-00, caBIG-dataload-0, merge-trunktag-bobdev_news-1, merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Changes since 1.2: +4 -1 lines
Create mapped gnum/pnum pairs instead of fig ids on output.
Mon Jun 20 19:04:32 2005 UTC (14 years, 9 months ago) by overbeek
Changes since 1.1: +5 -1 lines
generalize computation of close genes
Sat May 7 20:57:47 2005 UTC (14 years, 10 months ago) by overbeek
CVS Tags: Root-bobdev_news
add routines for BigFC
