[Bio] / FigKernelScripts / make_cdd_ontology.pl Repository:
Log of /FigKernelScripts/make_cdd_ontology.pl
Wed Dec 12 22:53:23 2007 UTC (12 years, 2 months ago) by mkubal
specify database as argument
Fri Dec 7 16:54:40 2007 UTC (12 years, 2 months ago) by mkubal
use local sqlite
