[Bio] / FigKernelScripts / make_calls.pl Repository:
Log of /FigKernelScripts/make_calls.pl
Links to myrast_rel40: (view) (download) (as text) (annotate)
Fri May 27 14:42:19 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.2: +5 -24 lines
cleaned up auto_assign
Thu Aug 12 18:24:14 2004 UTC (15 years, 4 months ago) by overbeek
Changes since 1.1: +10 -4 lines
Added '-no_hypos' flag to supress function-assignments of "hypotheticals." -- /gdp
Mon Dec 1 20:46:40 2003 UTC (16 years ago) by efrank
Makefile:
All the rest:
